Trying to create custom stair
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
RevitDriver
541 Aufrufe, 6 Antworten
I am trying to create this custom stair. I chose the boundary, stair treads and stair path from this sketch I have underlayed, it it won't build the stair. Says only one tread created.
Beschriftungen (1)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: RevitDriver
Your sketch cannot overlap.
Create two straight runs, convert them to sketch and edit each sketch to match the design.  Then you can have them overlapping like what you show.
Nachricht 3 von 7
kh_jea
While @ToanDN 's suggestion will work and look nice, well decent (let's be honest Revit is terrible at stairs) in 3D and section the connection between the 2 runs will look weird.
Nachricht 4 von 7
RevitDriver
Thanks, that worked. I posted a few pics of how it turned out. The railings still leave something to be desired. Is Revit working on a fix for stairs?  These were much easier in some of the older versions.
Nachricht 5 von 7
RevitDriver
Here's the finished product. Thanks for all your help!
Nachricht 6 von 7
You can fix this by edit the railing path, select a segment and adjust Height Correction.
Nachricht 7 von 7
RevitDriver
Your Awesome! That worked.
