Message 1 of 8
10:02 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I used the following method to create new worksets based on link file names and it works out perfectly.
But the issue was that - the 2 new linked files got automatically hosted inside the Workset1 (the primary after shared levels & Grids) of the test revit file after the 1st run, I had to go manually to shift the links to its proper workset (to the new created ones).
Is there a way to automate this so that the linked files are placed to their namesake Workset only as created by the script and does not go to the Workset1.
Thanks for any ideas
