Put structural coloum
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
733 Aufrufe, 4 Antworten
trying to put structural coloum in a project.
When I put receive message in attachment 1 "None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
After if to 3d view they are in project but with worng constrain "bace and top constrains in level 1 and base offset at -2.5 m.
When I put a wall are base and top constrains are visible to modified, for structural colou not.
After I can mofidied but somone can say me how can I set the contrains before put the coloum in project to have the correct constrain instead of modifyed later?
Thank's
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
If change the command on the project is the same
Nachricht 3 von 5
Structural columns are placed below the level (to support the floor). So if you want to move them above level, go to 3d view, select the columns and change their top and bottom elevation.
Nachricht 4 von 5
Alfredo_Medina
Before placing the column in plan view, notice the option that says Depth (which is the default), and change it to Height. This is at the options bar, below the ribbon.
Nachricht 5 von 5
als Antwort auf: Alfredo_Medina
If choose depth colum go from top to base and is contrary fro height is the opposite, right?
Why next to level in the ribon there is the number 2500 (that is the defaut dimension which go, in the begin, down from level 1) if I constrain the column in the levels?
