Hi, I tried to place a Spot Elevation on the ceiling plan. Somehow, Revit doesn't allow me to place the spot, and shows a symbol like I drew. Can anyone have an idea to solve this problem? Thanks a lot.
Solved by RDAOU. Go to Solution.
The view Visual style is set to Wireframe
Change the visual style to Hidden Lines or any other mode/style
You're welcome
