Level heads color mismatch
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
studioPZDLB
353 Aufrufe, 3 Antworten
My level heads should be black and red, and it looks black and red when the Level Head Circle family is opened. But when loaded into project it looks blue. The Lines (Level Heads) looks black in Object Styles. The red is a Filled Region called Solid Orange, which I don't know where to check. Please help. Thanks.
Family view
Project view
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: studioPZDLB
@studioPZDLB
When he level has views generated (floor/ceiling plans)  it will turn blue ... This indicates that it is a live link
Nachricht 3 von 4
studioPZDLB
als Antwort auf: RDAOU
Ok, now I remember. There is no way to overwrite it?
Nachricht 4 von 4
RDAOU
@studioPZDLB
You can override the line only...the head will always show blue when live
However, when you print you have that option to either print them blue (option checked)or print them with the colors you set up in the family or the Overrides (uncheck view link in blue)
=> when you print in color and have that box unchecked in the print settings...you will have them in Black and Red or orange or whatever color you have there
