Need Alternative for curved path on line-based family
anthony_iskandar
anthony_iskandar
I know I maybe too lazy to search on each post on this forum, but can someone suggest me the alternative to make this?Nangang Jingmao_tonynkyc.jpgThe condition is, this park bench, have the same profile, but the path is different every bench, I made this using model in-place, sweep, I used two profiles there. The result, every bench have their own family (because of using model in-place), which I don't like.
I was thinking there should be line-based family that can be applied to curve line, but even Autodesk Support said this is not possible https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/I... . I found some ways, Dynamo, Adaptive Family, though I have not looked deep into those things because I am quite new in Revit, which way should I go? Dynamo, Adaptive Family, or is there another easier way to do this?
syman2000
You can use railing to create this.
ennujozlagam
yes you can create as railing suggested by @syman2000 . you need to create a profile like your bench and load and use a railing to create this. sample here. thanks
anthony_iskandar
