Wall cut pattern 2019
Manoj.dDA93Q
Manoj.dDA93Q
Hi there,
I have drawn a wall in plan and have a used a filter to show a specific color for the wall. Both surface and cut patterns are filled in the filter region.
The lines are filled in as well and change color so the filter is working. Any reason why the pattern is not showing up?
ennujozlagam
https://forums.autodesk.com/t5/revit-architecture-forum/advanced-phase-filter-cut-pattern-display/td...
Manoj.dDA93Q
Phasing was not the issue. All are in new construction phase.
If I change the discipline from Mechanical to Coordination, the pattern starts showing up. Any reason for that?
ennujozlagam
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
