I know I maybe too lazy to search on each post on this forum, but can someone suggest me the alternative to make this?The condition is, this park bench, have the same profile, but the path is different every bench, I made this using model in-place, sweep, I used two profiles there. The result, every bench have their own family (because of using model in-place), which I don't like.
I was thinking there should be line-based family that can be applied to curve line, but even Autodesk Support said this is not possible https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/I... . I found some ways, Dynamo, Adaptive Family, though I have not looked deep into those things because I am quite new in Revit, which way should I go? Dynamo, Adaptive Family, or is there another easier way to do this?
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
You can use railing to create this.
yes you can create as railing suggested by @syman2000 . you need to create a profile like your bench and load and use a railing to create this. sample here. thanks
My question continued to this https://forums.autodesk.com/t5/revit-architecture-forum/segmented-curved-profile-in-railing-family/t... Please help ![]()
