Naming standard project set up
job.placenciaT45EX
job.placenciaT45EX
I cant seem to set up a project in the cloud after having enforced a naming standard on the folder.
If I do not set up a collaborative cloud project and just upload a simple Revit file to the same naming enforced folder it works fine. So I cant seem to figure out what the problem is.
Any ideas?
Im using Revit 2021
rxi.gg
I don't undestand the problem, could you explain that in other way?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
