Strange behaviour in Schedules - Count can't be used in formula
ron_adst
ron_adst
Goodmorning
I have to count something I did not model.
So in the Schedule I Put an extra culumn. I wanted to  make that culumn times Count and I got the next popup.
OK?
So I made a new culumn and manualy put the number of items there. (The count)
And then I freaked out. Way to many Items????
Then I put an 1* instead of the manual numbers and it works.
Maybe time to change the popup in (You can use Count by putting 1* in the formula) ?
ron_adst
Tried again...
Noope, doesn't work?
I don't understand what you are trying to do?
I don't read German(?) either.  Ich nicht verstehen.
Can you post something we English-speaking folk can interpret?
If you create a column to manually enter a number for quantity and you unitemized the schedule then you cannot set the parameter to calculate totals.
