@aRcHiTeCt.JM wrote:
... I guess I 've missread your post
.... short answer to get back that box that you 've checked:
... Unfortunately, right now there is no way to UNCHECK the checkbox through the Revit interface. The only way to manage it once you can no longer see it is via the Revit.ini file.
You want to look for SuppressConfirmLevelRename and/or the SuppressConfirmPlanViewRename settings under the Messages section of the ini file. The settings are:
- 0 = display the dialog box and user answers Yes or No
- 6 = user has selected Yes and checked the “Do not show me this message again” checkbox
- 7 = user has selected No and checked the “Do not show me this message again” checkbox
So this is how you can undo that checkbox if you hit it accidentally. It’s also a way for BIM Managers to set it to “7” and force people to rename their views and levels independently.
But who would be that sneaky…
my Revit.ini file is pretty uneventful "SuppressConfirmLevelRename" or "SuppressConfirmPlanViewRename' not in there....
[Revit.ini]
[Colors]
[Directories]
ProjectPath=%USERPROFILE%\Documents\
ImportLineweightsNameDWG=C:\Program Files\Autodesk\Revit 2019\Data\importlineweights-dwg-default.txt
MaterialLibraryFiles=..\Data\Rendering
IESFileLocation=C:\ProgramData\Autodesk\RVT 2019\IES\
LookupTableLocation=C:\ProgramData\Autodesk\RVT 2019\Lookup Tables\
[DirectoriesENU]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\English_I\
DataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\US Imperial\Detail Items
DefaultTemplate=Construction Template=C:\ProgramData\Autodesk\RVT 2019\Templates\US Imperial\Construction-Default.rte, Architectural Template=C:\ProgramData\Autodesk\RVT 2019\Templates\US Imperial\default.rte, Structural Template=C:\ProgramData\Autodesk\RVT 2019\Templates\US Imperial\Structural Analysis-Default.rte, Mechanical Template=C:\ProgramData\Autodesk\RVT 2019\Templates\US Imperial\Mechanical-Default.rte
[UserInterface]
[Language]
Select=ENU
[Applications]
Mechanical=0
Electrical=0
Architectural=1
Structural=0
[InstallationSettings]
Language=ENU
Usage=All
[Install]
InstallGUID={A87BCF51-7CF2-4B55-A14B-6A5924B96EAD}
[DirectoriesCHS]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Chinese\
DataLibraryLocations=Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\Generic\
DefaultTemplate=构造样板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHS.rte, 建筑样板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHS.rte, 结构样板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHS.rte, 机械样板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHS.rte
[DirectoriesCHT]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Traditional Chinese\
DefaultTemplate=建構樣板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHT.rte, 建築樣板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHT.rte, 結構樣板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHT.rte, 機械樣板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHT.rte
[DirectoriesCSY]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Czech\
DefaultTemplate=Stavební šablona=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CSY.rte, Architektonická šablona=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CSY.rte, Konstrukční šablona=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CSY.rte, Mechanická šablona=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CSY.rte
[DirectoriesDEU]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\German\
DefaultTemplate=Construction-Vorlage=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_DEU.rte, Architektur-Vorlage=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_DEU.rte, Ingenieurbau-Vorlage=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_DEU.rte, Gebäudetechnik-Vorlage=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_DEU.rte
[DirectoriesENG]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\English\
DefaultTemplate=Construction Template=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ENG.rte, Architectural Template=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ENG.rte, Structural Template=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ENG.rte, Mechanical Template=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ENG.rte
[DirectoriesESP]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Spanish\
DefaultTemplate=Plantilla de construcción=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ESP.rte, Plantilla arquitectónica=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ESP.rte, Plantilla estructural=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ESP.rte, Plantilla mecánica=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ESP.rte
[DirectoriesFRA]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\French\
DefaultTemplate=Gabarit de construction=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_FRA.rte, Gabarit architectural=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_FRA.rte, Gabarit de structure=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_FRA.rte, Gabarit de génie climatique=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_FRA.rte
[DirectoriesITA]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Italian\
DefaultTemplate=Modello di costruzione=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ITA.rte, Modello architettonico=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ITA.rte, Modello strutturale=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ITA.rte, Modello meccanico=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ITA.rte
[DirectoriesJPN]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Japanese\
DefaultTemplate=建設テンプレート=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_JPN.rte, 建築テンプレート=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_JPN.rte, 構造テンプレート=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_JPN.rte, 機械テンプレート=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_JPN.rte
[DirectoriesKOR]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Korean\
DefaultTemplate=시공 템플릿=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_KOR.rte, 건축 템플릿=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_KOR.rte, 구조 템플릿=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_KOR.rte, 기계 템플릿=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_KOR.rte
[DirectoriesPLK]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Polish\
DefaultTemplate=Szablon konstrukcji=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PLK.rte, Szablon architektoniczny=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PLK.rte, Szablon konstrukcyjny=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PLK.rte, Szablon mechaniczny=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PLK.rte
[DirectoriesPTB]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Portuguese\
DefaultTemplate=Modelo de construção=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PTB.rte, Modelo de arquitetura=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PTB.rte, Modelo estrutural=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PTB.rte, Modelo mecânico=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PTB.rte
[DirectoriesRUS]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Russian\
DefaultTemplate=Шаблон строительства=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_RUS.rte, Архитектурный шаблон=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_RUS.rte, Шаблон несущей конструкции=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_RUS.rte, Шаблон механического оборудования=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_RUS.rte
