Place a normal door in a Curtain wall
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
mairh_tsek
562 Aufrufe, 2 Antworten
Hello all,
Is there any workaround in order to place a norma doot to a curtain wall?
Thank you in advance!
2 ANTWORTEN 2
Nachricht 2 von 3
Alfredo_Medina
als Antwort auf: mairh_tsek
First, load a normal wall as a panel in the curtain wall. Then you can place a normal door in that wall.
Nachricht 3 von 3
cbcarch
To explain a bit further:
-You may need to make a thin (1" thick to match glass for instance) Wall Type.
-Then, use Tab key to highlight the curtain panel, unpin it, and select the thin wall as the panel type.
-Then, as Alf says, place a normal wall hosted door into the "wall" panel.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
