How to make L shaped corner curtain wall panel in Revit
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
4430 Aufrufe, 10 Antworten
Hi Everyone,
Recently I have a problem and here is the picture. I want to create the family of this corner panel D-A-9 but I dont know how to do it.  It is noticed that this is a panel actually not the corner mullion.  Also, I am quite interested in how to let this in place using curtain systems. Could you please help me? Thank you very much. 578967533.jpg
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: Anonymous
 Model In-Place.
Nachricht 3 von 11
dzanta
Start with the Storefront wall type.
User the "L Corner Mullion 5" x 5" Corner" Mullion for the border mullion
Click Edit Type and duplicate
Change material to Glass
Change thickness to match thickness of panel (i.e. 1")
Change offset to align panels faces
See image attached.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 4 von 11
David_Knight
als Antwort auf: barthbradley
Yep.  Model that whole corner piece.  Then just but your storefront standard pieces into it.
Nachricht 5 von 11
David_Knight
als Antwort auf: dzanta
this method doesn't account for a top, bottom, or middle mullion which it surely will have.
Nachricht 6 von 11
dzanta
als Antwort auf: David_Knight
I didn't realize your issue was for horizontal mullions too.  From the picture, it looked like you just needed help on a vertical corner mullion situation.
For the horizontal mullions, what shape is the horizontal mullion?  You can create a custom mullion profile and use this within the Type Properties of the curtain wall.
Watch this video to learn about how to modify curtain walls and profiles:
https://www.youtube.com/watch?v=aKreV7BBSSQ
Nachricht 7 von 11
You can TAB select the panels and edit in place to miter them.  Screencast in a few minute.
Nachricht 8 von 11
This is what I was thinking  because the OP said "this is a panel actually not the corner mullion".
Nachricht 9 von 11
Yes, this is exactly what I am saying. I know the model in place or void cutting is a solution but I just want to know is there some way that we can model this in a family? So it is possible to extract some useful information from it such as surface area and generate the schedules for the whole building.
Nachricht 10 von 11
You can create a panel family with a mitered end and a proper setback distance so that when you replace the two corner panels with the panel family, they miter properly.  Then you can schedule them normally.  Another option is Paint the surfaces you want to schedule and filter a material take-off schedule using As Paint field, that way you can use either a model in place L shaped panel, or system panels edited in place as shown in my screencast, or even thin L glass walls.
Nachricht 11 von 11
You can label dimensions with shared parameters in an in-place component just as you'd do in a loadable component. And you can include formula-driven parameters (e.g. Volume=Length*Height*Thickness or, Area=Length*Height).
