My Revit models are blue
ezio16
Message 1 of 14
ezio16
One day of sudden, when i opened a model in revit all my materials looked blue, like in the picture, i already looked at the materials...
Someone can get me a hint of what is happening.
Grateful since now,
Ezio Alves.
PS: Sorry for any misspelling, english is not my mother language.
Accepted solutions (3)
Replies (13)
Message 2 of 14
Sahay_R
Nice model!
Go into each material, and make sure that Use Render Appearance is checked.
If this is not checked, then the model will take on the color that you see - in my case, it would be the grey.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 14
ezio16
Hi Rina Sahay,
Thank you for answering, but checked and unchecked, my materials still show in blue color.
Thank you anyway.
Ezio Alves.
Message 4 of 14
What color are they supposed to be?  Can you edit the material and show screenshot of the Graphics and Appearance tabs?
Message 5 of 14
Sahay_R
Can you share the model?
Rina Sahay
Message 6 of 14
ezio16
I will link my model, i hope it is not too big, and will, show how my material should look by images
I really think that the problem is in my computer, because all my models are with this shades of blue.
Message 7 of 14
Sahay_R
Rina Sahay
Message 8 of 14
Viveka_CD
Thanks for testing @Sahay_R
Hi @ezio16
Sorry to hear that you are facing graphic issues.
Please try the following recommendations:
  1. Try disabling Hardware Acceleration within Revit. If this clears the behavior, then it indicates the issue is with the Graphics Card / Graphics Driver. Start by updating the graphics card (or by loading a certified driver version, if the card has been certified). Note: If a certified driver is already loaded, uninstall and then reinstall the driver (in case the installation is damaged).
  2. If disabling Hardware Acceleration does not clear the issue, check the following:
    • Is the issue specific to a single project?
    • Is the issue specific to a single system (or user account)?
    • Has Revit been updated to the latest build?
    • Try addiing OptimizedViewNavigation=0 to the revit.ini (find the revit.ini at this location:C:\Users\<username>\AppData\Roaming\Autodesk\Revit\<product name and release>)
Let us know if you were able to resolve the issue.
Message 9 of 14
ezio16
Hi Viveka,
It was really my graphic card, my issue is solved. Thank you very much.
Kind Regards,
Ezio Alves.
Message 10 of 14
Viveka_CD
Hi @ezio16
Good to hear that.
Let us know if you have any more questions. Glad to help.
Message 11 of 14
a_esmaeil
Solved! See below.
Message 12 of 14
Viveka_CD
Hi @a_esmaeil
Welcome to the Autodesk community! Smiley Happy
I'm glad to note that your first post relates to a solved post, thanks for sharing!
Message 13 of 14
krm6hq
Community Visitor
Community Visitor
Hello, I've been having the same issue with my model being blue. I've tried to turn off hardware accleration, but that doesn't work for me. It is the same across all of my project files.
Message 14 of 14
Sahay_R
Is anyone else experiencing this behavior?
Have you tried the above suggestions?
Rina Sahay
