My revit file size is not reducing after purge & Compact
bhudevdas1994
Message 1 of 11
bhudevdas1994
My Overall Model File size is 1.3gb when i am segrigating the model it showing 1.07gb size. after purge and compacting model also file size is increasing. Please help.
Replies (10)
Message 2 of 11
PavelAnd
Hello @bhudevdas1994Delete all unused families, annotations and so on. And try saving the file again as a new one with a different name. This helps reduce the weight of the model.
Best regards, Pavel Plotitsyn.
Message 3 of 11
bhudevdas1994
I did the same also. But it coming same File size.
Message 4 of 11
PavelAnd
Do you have CAD files inside the project? If you used "Import CAD", then delete them and try to use "Link CAD". If you have families with CAD geometry in your project, then they also make the model heavier.
Message 5 of 11
bhudevdas1994
I have no imported cad in Revit. All Families used in project only 16mb. But file size is not reducing.
Message 6 of 11
PavelAnd
How many elements are in your model? Perhaps it will be more correct to divide it into parts?
Message 7 of 11
zxron
In most cases revit file size increases if there are many families with cad geometry. You need to check them.
Also for optimazing your you can split project by moving some elements to another files by category for example, and link files into one main fproject.
Message 8 of 11
bhudevdas1994
My revit families have no Imported Cad. If you want please share your email Id I will share my revit file for your review. From my side everything is okay. but don't know why size is not reducing. Help please.
Message 9 of 11
zxron
You can send link to file to this email shahabudin@mail.com
I'll try to help you
Message 10 of 11
MostafaElashmawy
yes share the file if possible.
Mostafa Elashmawy
Message 11 of 11
martijn_pater
How many times did you purge it? 3?
You could also consider/adopt a bim360 workflow...
