duplicate view modification
hi, how can i do modifications on duplicate 3d view without any changes on original 3d view, but i want to change something in duplicate 3d view for detailing purpose
martijn_pater
Right-click the view in project browser and duplicate the 3D view with or without detailling. Possibly lock the view (that's the 'little house with lock' symbol at the bottom, 'Save orientation and lock view').
thank u for ur reply,
i tried this but when i modify on 3d duplicate view at the same time 3d original model also changing
martijn_pater
Either you copied it as dependant view... or you are trying to model different options . See below link:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Perhaps add an image of what you are trying to do, if that wasn't it...
RDAOU
@Anonymous
3D view are live linked to each other...any modification to elements in one will be reflected on all other views and will be visible in views where that element is visible too.
Hence the question is what are you trying to modify? maybe what you are doing require that you use something like:
  1. Design Options
  2. Phasing
  3. Worksets visible only in that specific 3D
  4. use of a certain families visible only in that specific 3D
You need to elaborate
