Dynamo Display problem(4K Display)
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
ArdillasNuh
692 Aufrufe, 5 Antworten
Anyone can help me for a long time my dynamo revit and dynamo studio display seems greatly jagged and if i rotate the model inside dynamo the refresh rate happens so low. the opposite way in the revit file, geometries and model rotation are smooth. Anyone have same problem? My display is 4k and gpu gtx 1070.
5 ANTWORTEN 5
Nachricht 2 von 6
RDAOU
als Antwort auf: ArdillasNuh
@ArdillasNuh
4k screen could contribute to this but I do not think the slow refresh/regen rate is entirely related to your 4k screen...GTX 1070 a good gaming gpu but it isn't really a top range one. Im using a 1080 on my laptop and I think its performance somewhere between average and below average (4/10) when working with attractors or considerable amount of repeaters.
Try to disable graphic acceleration - it is not really a solution but just try it to see if there is any noticeable difference
Nachricht 3 von 6
ArdillasNuh
als Antwort auf: RDAOU
Thank you for the answer, by the way it happens only for my dynamo screen, not for my revit screen(my revit screen refresh time is quite okay in 4K display, quite the opposite my dynamo screen is daunting and jagged refresh rate :erschöpftes_Gesicht:) .
Nachricht 4 von 6
RDAOU
@ArdillasNuh
Which version of Dynamo are you using and Which version of Revit?
If you have any older/previous versions of Dynamo it might be a good idea to remove them and leave only the latest.
Nachricht 5 von 6
ArdillasNuh
@RDAOU,
I am using Revit
20.2.0.48
20191031_1115(x64)
2020.2
and dynamo
Or maybe my dynamo installation is not clean from previous version? How to install cleanly? My dynamo studio also experiencing graphic jagged and poor refresh rate too.
Nachricht 6 von 6
RDAOU
@ArdillasNuh
That version 2.3 is packaged as part of Revit 2020...you can always install a previous/more stable versions from DynamoBIM.org … I would recommend to go for version 2.01 considering that there are some good user packages which have not been updated yet and are/may cause issued with 2.3
