Multiple Revit versions on single workstation (2014, 2015, 2016)
4 REPLIES 4
2528 Views, 4 Replies
Can I properly install standalone Revit 2014, 2015, and 2016 on the same workstation without conflicts or other bad results, if I install them in that order (2014, then 2015, then 2016)?
It seems that I have heard that TWO versions on the same workstation is the limit, that THREE versions is a real problem. True?
4 REPLIES 4
paullimapa
I think the problem occurs when you accidentally open & save an older version Revit file with the latest Revit 2016.  Then you won't be able to open it again in the older Revit version.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
in reply to: paullimapa
Thanks for your prompt reply. Understood. What I want to do is to bring projects done in an earlier version for4ward to the current version. Opening them in the older version again is a solvable problem. My concern is with the truth or falsity of statements I've heard that just having more than two Revit versions on one machine is a real problem. If true, I would not do it. If false, then I'd go ahead and install 2016 on the same machine instead of using a different machine.
You can have 3 versions of Revit per licensing....so 3 versions on a computer.  All of our computers have 2014-2016 installed.
Thank you.
