Complex roof help
3 REPLIES 3
raresh1905
306 Views, 3 Replies
Complex roof help
raresh1905
hi there,
i have this roof shape 1.PNG .
i need this roof in one slope like this one Roof+Slope+Arrow.jpg curved, but when i get in shape editor mode my roof look like this 2.PNGand if i will offset one line i wont get the same image that i want. so basically i want that shape of roof with my boundary. can someone help me? or can i be done?
thanks,
Complex roof help
hi there,
thanks,
3 REPLIES 3
constantin.stroescu
In such a case I'd use one of the following two methods:
  1. Mass Element and Roof gy Face - First create an extruded Mass using as basic shape your contour.Create then Void Extruded using as Work Plane a Vetrical Reference Plane ( this Reference Plane ought to have a name in order to be a valid Work Plane) . Once created the Mass Element,use  Roof by Face
  2. Roof by extrusion( or Roof by Footprint wit one slope) cutted by a Component > Model in Place >Roof - make a void -Extruded component using as Work Plane the curent Level (the extruded void component has to be hollowed with your shape profile)
my favorite method would be method 1
Constantin Stroescu
Constantin Stroescu
constantin.stroescu
I 've attached here the screencasts that depict the two methods from my previous post:
1.Mass element +Roof by Face
2. Roof by Extrusion( could be also by Footprint) combined with a Void Component
Constantin Stroescu
Constantin Stroescu
constantin.stroescu
if you want a helix shape roof , you can do it using Conceptual Mass to make the basic shape. Conceptual Mass allows you to work with subelements of the mass ( Edge , Surface and Points) In our case we wil use either Edge or Surface , drag them verticaly to obtain the helix.
The mass thus obtained can then be combined with a Void to obtain the desired projected shape.
If you need roof with layers and roof definition , then , once the mass finished , use Roof by Face.
Constantin Stroescu
Constantin Stroescu
