Multiple revision numbering
Message 1 of 28
Hi
Is there a way to use multiple revision numbering system?  What I mean is for every stage of a project to have a diferent prefix on revision. Preliminary as P01, P02, P03 and so on, than for Tender: T01,T02,T03 and so on, and than for Construction: C01, C02, C03....I've tried to use numeric with prefix and alfanumeric as fixed figures but that work only with 2 systems and at first place alfanumeric have to be used othervise revision shedule is not in the right order.
Replies (27)
Message 21 of 28
dtobitt
Observer
Observer
That looks like it would solve our problems, I still don't seem to be able to find it, which tab is it under please?  The search doesn't offer any assistance for 'revision properties' either.  Much appreciated, Donna
Message 22 of 28
Tabs are shown in the screenshots: Fields tab and Sorting/grouping tab.
Message 23 of 28
dtobitt
Observer
Observer
Got it thank you, I failed to double click on the family to open the drawing sheet properties, there it was under sheets, thanks again
Message 24 of 28
asWAPL9
going back to revit 2021, is it possible to get the numbering as P01, P02 instead of just P1, P2? our document manager requires two indexes after P and C.
Message 25 of 28
avalavani
We've tried something similar previously, but this meant that we had to put entries manually and needed to create by far many more revisions which were not only date-specific, but also sheet-specific and this ended up in many errors and a chaotic list of revisions. In a large team where there could be more than 10 revisions added per day because of this approach, member of the team often confuse the revisions ticked and this is a problem when issuing contractual documents.
Why can't Autodesk update this function in Revit and allow multiple numeric/alphanumeric entries, so that it can satisfy the requirement and also promote automation, which a software is supposed to do in principle?
This has been an industry-wide ongoing problem for far too long.
Message 26 of 28
avalavani
Yes, you choose your P series to be Alphanumeric and include the 0 in the sequence you want.
For us, it's unlikely that our T issue will go more than 9 issues, so we set it up like shown in the screenshots below.
I hope this helps!
Message 27 of 28
mviscettoVGK6V
Thank you for the tips, I created a cheat sheet for my group and myself for when I need to do this again.
See attachment, hope that helps.
MV
Message 28 of 28
mviscettoVGK6V
Super helpful - Got me to the solution. - thanks
MV
