Multiple levels on same height, problem with IFC-export
- Mute
- Permalink
- Report
I have a model thats going to be used in facility management.
Note that I have'nt been a part of the process until now. The house is already built.
Using Revit 2020.
The model contains two buildings that are more or less modeled as one. One of the buildings is called 100 wich is a existing building, and building 500 wich is a new building joining the exisiting 100 building. Phases has not been used.
There are two sets of levels ( from level 09 up to 17), one set for building 100 and one set for building 500, for example: level 09_100 and 09_500. All levels are defined as Building Storeys.
When I export this to IFC all of the levels come out correctly, except for one level, level 12_100.
What happens is that all the objects that are associated with 12_100 ends up in the 12_500 level. When looking at the IFC in notepad/Solibri/SimpleBIM the 12_100 level simply doesn't exists as a Building Storey.
After investigating the basics I can't find whats wrong in Revit with the 12_100 level. Everyting looks fine, same as in the other XX_100 levels.
The only thing I can see is that all the other levels are in different height between the two buildings, so level 09_100 and 09_500 is not in same elevation, height of level. However the 12_100 and 12_500 is at the same height.
Does anyone know what the problem is and how to solve it?
I ran in to this when I was splitting the ifc in SimpleBIM and wanted to use the different levels to easy exclude the one building from the other. I'm not depending on the levels for this but I really want to know.
Thanks in advance.
/Ello
