Can not cut void in family
5 ANTWORTEN 5
Nachricht 1 von 6
ssw9UZNL
367 Aufrufe, 5 Antworten
For some reason, there is a particular void that will not cut in one of my curtain wall families.
The void overlaps the element- and I can not work it out- I have succesfully done it for other scenarios but this one just seems to fail.
Please refer to image below and I have uploaded the family.
5 ANTWORTEN 5
Nachricht 2 von 6
ssw9UZNL
als Antwort auf: ssw9UZNL
This is another example. but this is the glass element.
I can successfully cut the void anywhere the wall is located- but as soon as I lock it to a particular reference line (the one I want the element to be locked to)... the void can no longer cut- either side, to the side of this reference it works fine- just not on the reference. 
Nachricht 3 von 6
FAIR59
This would be the result of the cut, but with the small prism penetrating the main geometry  by a (very) small amount. Unfortunately your design is on the point where Revit will object. CutResult.PNG
Nachricht 4 von 6
ssw9UZNL
als Antwort auf: FAIR59
@FAIR59  thanks for looking into this.
Are there any work around here?
Nachricht 5 von 6
FAIR59
Nachricht 6 von 6
ssw9UZNL
It looks like the issue occurs when you try and cut too small of a piece- as per the image.
As i have lots of instances of these and its parametrically driven, I cant account for all of them.
is there any work around?
