Multiple employees working in one area of one file
pwhiteSTG
Message 1 of 18
pwhiteSTG
We have a model where we have 2-5 people in the model at one time. The entire model has been drafted in the architectural workset. We are running into an issue of only one person being able to work without the others syncing every move. I have set up everyone on different worksets and only one workset is editable per person. Still happening.
What are we doing wrong?
Replies (17)
Message 2 of 18
Yien_Chao
nothing wrong here. worksket is a good way to separate task or region in a project. your team need to understand even if they modify only their elements in their workset, it is possible that certain elements also lead to the modification of other elements in the other sub-projects. ex : wall connection to another wall.
Message 3 of 18
pwhiteSTG
Okay that is making more sense. So adding furniture that is floor based on FURNITURE workset but the floor is on ARCHITECTURAL, it will still cause a sync?
Message 4 of 18
Yien_Chao
yes in theory
Message 5 of 18
Are people owning or borrowing worksets?
Message 6 of 18
pwhiteSTG
This is where I am not too familiar with it. I am not sure if I am owning or Borrowing. When I just have one workset set editable, I am the owner. Each other person does the same with a different Workset.
 This is what it looks like. Right now I do not have anyone in the model so I cant show it with multiple people.
Message 7 of 18
You are owning the Architectural Workset which you should not.  Highlight teh workset and click Non-editable button to release it.  Then sync.
Message 8 of 18
pwhiteSTG
Okay I got another person in the model and we both did that and I still had to have him sync for me to add a new wall...
Message 9 of 18
Are you adding walls in a model group?
Message 10 of 18
pwhiteSTG
Negative. Right now only one person is allowed to model anything at one time. There must be something wrong.
Message 11 of 18
Yien_Chao
Stupid question : are you all in the central file??
Message 12 of 18
pwhiteSTG
Probably a more stupid answer haha but we use BIM360. Is that our issue?
Message 13 of 18
Yien_Chao
Nope. Then that should be fine.
Can you invite me in private? I will take a look on my lunch time.
Message 14 of 18
pwhiteSTG
Sorry for the late response. I think I found the issue. Right now we have design options set up. We only have one option set and 3 options. We are all trying to work in option 3. Is that the issue?
Message 15 of 18
Yien_Chao
haaa! ok . it's only one person at a time on each option.
Message 16 of 18
Yes.
Message 17 of 18
pwhiteSTG
Any solution to setting it up to allow multiple people in it at once?
Message 18 of 18
Yien_Chao
i would suggest to fixed the "untouched" design in the MAIN MODEL.
then create a new option set (like  Area - A) and keep the primary EMPTY as long as you didnt decide the final design.
then add new options in the option SET A, like 1,2,3 so each person CAN design in their option. remember to keep the primary option untouched.
y
