Am creating our template for kitchen upgrades, in CAD we have a table which has the multiple choice the tenants get for the finshes as attached. How would you go about creating this in Revit as there doesnt seem to be a table function.
Solved by ToanDN. Go to Solution.
Solved by www.TechRoom.bg. Go to Solution.
You can add meterial choice for your family like a parameter.
Here is official information from Autodesk about creating family parameters.
Here is official information from Autodesk about Shared prameters.
I think its easy to make your table parametric but if you need more help about it post your family and tell us what exactly do you need to do.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
You can. Create a bunch of Yes/No parameters and assign them to you family category. See the casework schedule example (2016):
