Mullions with different materials
Marcus.Isacsson
Message 1 of 21
Marcus.Isacsson
Hi fellas!
Is it somehow possible to have several materials for curtain wall mullions?
Replies (20)
Message 2 of 21
Ilic.Andrej
You can have several curtain wall mullion types....
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 3 of 21
Marcus.Isacsson
Not what we're aiming for. We want to show the same window with different materials for different parts.
Do we have to create a window family instead?
Message 4 of 21
Ilic.Andrej
When working in project, hover over the curtain wall, hit tab to select the mullion, click to unpin it and then you can change its type from the type selector.
Andrej Ilić
MSc Arch
Message 5 of 21
Marcus.Isacsson
We want a different color for the inside and outside of the mullion.
Message 6 of 21
Yien_Chao
paint it?
Message 7 of 21
Marcus.Isacsson
@Yien_Chao wrote:
paint it?
Could be a solution.
Feels so unneccessary and time consuming though, when we want this to done the same way for 100+ windows.
Message 8 of 21
Ilic.Andrej
It really depends on the size and purpose of the glazing. If it has only two or three divisions, I don't see a reason not to do a window family. But if its something large for which you need the flexibility of curtain walls, maybe you could model two curtain walls and stack them together. One could have only the exterior mullion caps, while the other one could have the interior mullions and glass panels....
Andrej Ilić
MSc Arch
Message 9 of 21
Yien_Chao
which sides do you want to paint actually? does it have silicon for exterior or it is with caping?
Message 10 of 21
Marcus.Isacsson
For those it's a cap.
The main question is if it's possible at all to have curtain wall mullions where different parts have different colors.
Message 11 of 21
Yien_Chao
i dont think so. its an extrusion from a single close profile and you cannot assign material to profil, but the whole extrusion.
Message 12 of 21
martijn_pater
If you want to have a cw mullion with two-sided material, only way to do that is to paint it I think. Since there are no different parts.
Message 13 of 21
You could model the mullions in the custom panels.
Message 14 of 21
Marcus.Isacsson
I just tried the paint tool, didn't get it to work (curtan wall mullions)
Message 15 of 21
Marcus.Isacsson
Was thinking about this as well. Are custom panels allowed to contain several materials?
How would the inside part of the mullion be modeled in a custom panel? Just a thin "sheet"?
Message 16 of 21
A custom panel can consist of different surfaces that you can paint them with materials or material parameters (for the flexibility to change materials in the project).
Message 17 of 21
martijn_pater
You're right, it was the only way I could think of that might work with mullions. With panel family you can add multiple material parameters though.
Message 18 of 21
martijn_pater
You could possibly add another CW in front of the other creating a double mullion for front/back? Upvoted the suggestion on the idea forum for painting mullions, made sense to me to be able to do so anyway.;)
Message 19 of 21
Phil.Tu
Community Visitor
Community Visitor
Thats what I am thinking too. But I wish Revit could provide better options for this situation.
Message 20 of 21
bneuSPJXV
Observer
Observer
In my use case, we want vertical fritted glass fins/louvers cantilevering from the center of the mullion from an integral mullion clip. This is used often enough, I'm sure there is an obvious solution, but I can only think of adding an extension in the mullion profile, but then it's assigned the same material as the mullion. Thoughts?
