MS Access not appear in DBLink Connection
4 REPLIES 4
320 Views, 4 Replies
when i try to "select new connection" in DBLink to make MS Access, i don't found This Topic/Words "Select new Connection", why??????
4 REPLIES 4
cbenner
cbenner
You need Access 2010 or newer - 64 bit.
Viveka_CD
Viveka_CD
Autodesk Support
Autodesk Support
Hi @Anonymous
Also, in your user's Data source config - check that the server's address is correct, check the password.  You can also try from command prompt to ping the db server from their PC to ensure that there isnt some different network issue.
Let us know if the recommendations help with your issue.
Hi @Anonymous
in reply to: Viveka_CD
MS Access does not require the data source definition.
