Moving a project in its entirety
20 REPLIES 20
Message 1 of 21
RJK42
942 Views, 20 Replies
I have a project that I am working on utilizing point cloud data.  As its stands the project's level 1 is at -4' 7 1/2".  I need to move the project up so that everything moves uniformly so that the level can be at 0'-0".  When I click manage, position , relocate project I will reference the Level 1 at -4' 7 1/2" to a reference line at 0'-0" but will still have the same elevation values.
I need level 1 = 0'-0".  I also need the point cloud and the model to move as well.
Thanks in advance
20 REPLIES 20
Message 2 of 21
in reply to: RJK42
edit...What a minute. Let's try this again. Are you Sharing Coordinates?
Message 3 of 21
in reply to: barthbradley
@barthbradley wrote:
Moved the Clipped Project Base Point with Survey Point up.
@RJK42
Unclip Project Base Point and move it to align with the Level 1.  Then re-clip it.
I think he meant that but made a typo.
https://knowledge.autodesk.com/community/screencast/847ce364-00e9-4fc3-981c-32a78f40517c
Message 4 of 21
in reply to: ToanDN
Yep, you're right. But, it was a knee-jerk reply in any case. A couple questions need be answered first.  Heck, the OP could even leave PBP where its at and still correct the elevation shown.
...I'm interested in knowing what the OP meant by "I have a project that I am working on utilizing point cloud data."  How would the project's Level interfere with doing that.  See where I'm going @ToanDN?
Message 5 of 21
in reply to: RJK42
I'm going to cut to the chase here.  You can't.   You need to manually move the Point Cloud.  But why do you need to change the Level's Elevation at all?
BTW: Moving the PBP unclipped will reposition the PBP -- but not Internal Origin, which is what your Point Cloud is anchored to you if brought into the Project directly.   A better way to do Point Clouds, is to put them inside a separate Revit File and Link that Revit file into your Project.
FWIW
Message 6 of 21
RJK42
I am sharing coordinates with the rcp file also I uncliped the project basepoint and survey point, repeated move project but it just shifited everything up without a change in the levels. right know the project basepoint and the survey point are at 0.  I need my level 1 to be 0 as it is -4' 7 1/2"
Message 7 of 21
RJK42
in reply to: ToanDN
it doses not work.  I unclip it, selected it, move it but goes right back to its original level
Message 8 of 21
RJK42
in reply to: ToanDN
I dragged it instead and it worked
Message 9 of 21
in reply to: RJK42
What do you mean when you say “I dragged it instead and it worked”?  Dragged what? The Point Cloud?  The Project Base Point? Both?
Dragging the Project Base Point while UNCLIPPED, as is shown in the Accepted Solution, would not move the Point Cloud.  So obviously, you did something else. Either that, or you didn’t move the Point Cloud. Which is it?
Message 10 of 21
RJK42
I unclipped the project base point and dragged it to my level 1 which changed all levels uniformly
Message 11 of 21
in reply to: RJK42
I see. So, you did NOT move the Point Cloud. I thought that was the objective. I must have misread your first post when you said: "I also need the point cloud and the model to move as well".
Message 12 of 21
RJK42
I meant to say I needed the rcp file to move uniformly with everything as well.
Message 13 of 21
in reply to: RJK42
Yeah, I get it. But, unclipping and moving the Project Base Point doesn't do this (move the point cloud).   And, if it did (which I doubt); I'd sure like to know how. This information would be very beneficial to me and others.
Message 14 of 21
Moving is relative. You can move a horse to its wagon, or move the wagon to the horse. Whatever is easier.
Message 15 of 21
in reply to: ToanDN
Do you have experience working with Point Clouds?
I thought not.
Message 16 of 21
I thought not.
I thought the same about your reading and understanding the context.
Message 17 of 21
in reply to: ToanDN
I thought not.
You know @ToanDN, it might be "Low-T".   You ought to go see a doctor.
Message 18 of 21
I thought not.
Thanks for proving my point!
Message 19 of 21
RJK42
I never had to adjusted the level to be 0'-0" until this project that I just finished.  I was afraid that after all the work I did to model from the cloud would be effected if I moved the project to a new position. By dragging the project base point to the a level that is 0'-0", everything relatively moved to allow me to set level 1 = 0'-0".  Its pretty much reset the level 1 to 0'-0" while all the other level values adjusted accordingly without effecting the elements within Revit.
Message 20 of 21
in reply to: ToanDN
No problem, buddy. Glad I could help.  And, don't worry; if the doctor can't fix that point, I'm sure reconstructive surgery can.  Good luck.
