Modeling Lines in Revit
AChiagoro
Message 1 of 10
AChiagoro
This is just a generic question,
I am trying to create lines in Revit that would show up in all views (all MEP disciplines). I have to callout rooms that will have 1-hour fire rated walls. The lines to callout each room that will be created have the following attributes below. The problems is that when it comes to using detail lines, I can't assign them to a family nor can I assign them to a workset. I don't know to much on using Model Lines, but can I assign model line to a workset and/or a family so that I can have them show on all views ? Capture of one of the rooms is attached.
To create the same line type:
-line weight projection = 6
-line color = black
-line pattern = dash 1/8”, space 1/8”
Thank you!
Replies (9)
Message 2 of 10
Unlike Detail lines, model lines will show in all view unless you deliberately turn them off.
Message 3 of 10
AChiagoro
Now, when you say "...deliberately turn them off", do you mean like turning off the model lines from the V/G within the model categories ?
Message 4 of 10
Yes.  And any other method you would use to turn model elements off such as filters or hide elements in view.
Message 5 of 10
AChiagoro
Thank you! I will try using model lines.
Message 6 of 10
AChiagoro
I ran into a problem where I used a detail line and made sure that all views have "Lines" model category turned on, but the model lines I create won't show in other views, I have made sure that the model lines workset were turned on as well. I still can't see anything.
Message 7 of 10
Are the model lines obscured by other things?  Are they within the view range?
Message 8 of 10
AChiagoro
Yes, I adjusted the view ranges and still nothing. Nothing would show up in the hidden view as well. I will continue to mess around with the view ranges. I have to be doing something wrong in my process. See attached files for current view, where the model line was created/drawn and another view where the model line are suppose to show up.
Message 9 of 10
AChiagoro
I got mines lines to show but another issue .......lol......by the way, thank you for your help. My question is that is there a way to have the models line show even though it goes through a wall ? See capture attached.
Message 10 of 10
No, unless the view is wire frame or the wall is transparent.
For what you are doing, I think using detail lines is more appropriate.  There are a couple approaches:
1. Detail lines in group:  draw detail lines directly in a view and group them, then copy paste the group to other views.
2. Detail lines in in-place family:
- create an in-place family (wall or generic category)
- draw detail lines
- model a 3d extrusion so that it will be cut by your view range cut plane, set the extrusion to invisible from property
- finish the in place model and you can have the detail lines in it showing in any plan/rcp view with a cut plane cutting the 3d extrusion
