Model Lines - display in Level Above
4 REPLIES 4
197 Views, 4 Replies
Hello everybody! Recently in new projects I open I have this problem
The lines from the level under are shown - of course green lines aside, I mean model linesThe lines from the level under are shown - of course green lines aside, I mean model lineswhile in 3d everthing's finewhile in 3d everthing's fine
I have tried playing with view range and Lines styles in Visibility/Graphics Override (VV) but nothing changes. May it have to do with Phasing? I've tried manipulating that a little too, but either nothing changes or the model disappears in toto.
I have tried to do this but it doesn't show any difference at all:
https://forums.autodesk.com/t5/revit-architecture-forum/model-lines-display-in-level-above/m-p/80410...
Thank you in advance
4 REPLIES 4
Change Underlay to None.
in reply to: ToanDN
Thank you! It works, but another problem has emerged. When I zoom in, some lines of the model disappear:
Like there, won't change even with fine detail modeLike there, won't change even with fine detail mode
and it persists when I print to pdf.
Not sure. What is your view range settings? Can you share the file?
in reply to: ToanDN
Of course.  Thank you a lot.
Forma Design Contest
Technology Administrators
