3D views camera
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
275 Aufrufe, 2 Antworten
3D views camera
I have created a toposurface of a large sloping area, which my client is trying to attach a camera view too. He says in the past he has been able to attach a camera to the surface itself, rather than an offset above a defined level.
I have looked at lots of forums and videos and have not found anything that says this is possible. Can it be done?
Thanks in advance
Phill
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
I don't remember this ever being possible.  What is the client trying to do?  Change the angle?  This can be done in Elevation by dragging the camera's end points.
Nachricht 3 von 3
als Antwort auf: barthbradley
Thanks for the response Bradley. The client is adding camera views for design purposes and said they may end up adding hundreds until the right view is found. As the toposurface is related to level 0 to ensure the contours from GPS data are at the correct level, the camera views are attaching to this level and coming in below the surface. The client is certain that in the past he has been able to attach the camera to the surface instead of relating to a level, I found no evidence of this from my research.
Thanks again for your response.
