Missing templates in Revit 2018
kim.sran
Observer Observer
Message 1 of 9
kim.sran
Observer
Observer
I don't see any templates and cannot open an autocad file in revit. Please help
Replies (8)
Message 2 of 9
DarrenP
read this about the Revit Content: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
how are you opening the autocad file?
DarrenP
Message 3 of 9
Are you saying you can't IMPORT CAD or LINK CAD (via Insert Tab)?
title renamed for clarity by @Viveka_CD
Message 4 of 9
ennujozlagam
@kim.sran
Are you trying to open AutoCAD files in Revit? You won't be able to open a .DWG extension into Revit only those files are openable in Revit = RTE, RVT, RFA and RFT files. As mentioned by @barthbradley, either you import or Link cad into Revit. Thanks
Message 5 of 9
markcalloway
Hi @kim.sran
Also if you are just missing the template list on the revit home screen you can add them back there by using the instructions on this page:
https://www.manandmachine.co.uk/customise-template-list-revit-home-screen/
Let us know if you managed to resolve your issue.
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
Message 6 of 9
Viveka_CD
Hi @kim.sran
Welcome to the Autodesk community! Thanks for posting on the Revit Architecture forum.Smiley Happy
As the first step, please install your latest updates from your Autodesk Desktop App. See HERE
See Download and Install: Revit 2019 & Revit 2018 Content (Templates and Families)
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Message 7 of 9
Hi all,
I have encountered a problem where I could not find Architectural template file in Revit 2018.  I have downloaded the Australia version Revit and ENU Imperial and metric template files. Is there any solution for this?
Another problem is the "wall" library has been missing in my template. What should I do?No Architectural template can be foundNo Architectural template can be found
Message 8 of 9
default.rte is the default Architectural.
Message 9 of 9
Viveka_CD
Hi @Anonymous
Can you try a Revit repair and see if this helps?
