Does anyone notice the MMB scroll is opposite in Windows10. Just saying because I upgraded from windows 7 and it is not the same.
Title edited for clarity by @Viveka_CD
is your scrolling the same as the default in Autocad? Because when I first installed revit on windows 7, it is the opposite. But now i upgraded to windows 10, it's the same now as the AutoCad default.
same scrolling, panning and zooming MMB functionality in both.
..Default? You're not talking about zooming, are you? AutoCAD's ZOOMWHEEL command will change the direction it zooms when spinning the wheel.
Hi @Anonymous
It's the same for me too.
You might want to take a peek at unsolicited auto-scrolling in the wrong direction from the Microsoft forums and the recommendations that follow.
Let me know if this helps!
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
