Missing Mullion when Exporting Revit to CAD
Hi all,
I'm trying to export a Revit floor plan to CAD. After exporting, everything shows up properly except that there is a type of mullion that does not show up. This only happens in Floor Plan views
Visibility - Checked
View Range - Checked
Export Setup - Checked
Family Type - Checked
Workset - Checked
The mullions inside the redlines are missing when exported to CAD.
The highlighted mullions are the same family but just different in size.
Revit:
CAD:
Softwares:
Autodesk Revit 2017
AutoCAD 2014
maybe the family has no lines showing in plan for that size
I am having the exact same strange issue. Any solution?
ennujozlagam
try to copy and paste that curtain wall in a new file then export to autocad and see what happen or you can shere the file here so we can check. thanks
andresmontemayor
I am also having this issue and think I have pin pointed the issue to the fact that it doesn't export the mullions if the Width is 1" or less. I tried with 1" (split on Side 1 and Side 2 of the curtain grid) and doesn't export. I tried with 1 1/32" (split as well) and it does export. Aside from this, I can't figure out why this is happening or how to fix it...
Has anybody found any solution to how to fix this?
