While opening the model from local drive, Revit 2018 throws error "The model .rvt is missing many elements, and it cannot be opened"
Please suggest solution for this issue.
You can try and open the file with Audit checked, but typically that warning means that you have a problem. You will probably need to find another users local file that can be opened and create a new central model.
