missing many elements, and it cannot be opened - Revit 2018
2 REPLIES 2
280 Views, 2 Replies
While opening the model from local drive, Revit 2018 throws error "The model .rvt is missing many elements, and it cannot be opened"
Please suggest solution for this issue.
2 REPLIES 2
You can try and open the file with Audit checked, but typically that warning means that you have a problem.  You will probably need to find another users local file that can be opened and create a new central model.
Forma Design Contest
Technology Administrators
