Missing Geometry (family) in Revit Model
4 REPLIES 4
joyUQQ7M
252 Views, 4 Replies
joyUQQ7M
Hello my revit model shows certain windows cutting through the walls in elevation but not in section, is there a way to fix this?
Labels (2)
4 REPLIES 4
ennujozlagam
in reply to: joyUQQ7M
ennujozlagam
try to activate your icon BULB it could be hidden in the view and see if helps.
ennujozlagam
ennujozlagam
check this
https://forums.autodesk.com/t5/revit-architecture-forum/windows-shown-in-elevation-amp-3d-wont-appea...
check this
syman2000
syman2000
Check and see if the window and the 3d is at the same phase. Right now I see it as 02_New Construction. If that isn't the issue, check design option and see if the window is in the wrong design option.
Check phasing of the 3d view (phase and phase filter).
