Hello my revit model shows certain windows cutting through the walls in elevation but not in section, is there a way to fix this?
Solved by ToanDN. Go to Solution.
Solved by syman2000. Go to Solution.
try to activate your icon BULB it could be hidden in the view and see if helps.
check this
Check and see if the window and the 3d is at the same phase. Right now I see it as 02_New Construction. If that isn't the issue, check design option and see if the window is in the wrong design option.
