Missing furniture in rendering- revit 2023
agrosantos
Message 1 of 10
agrosantos
I have a problem with rendering kitchen furniture. Some furnitures are missing in rendering. Things are happening sometimes also for furniture that werent missed in older renders.
Here are attchments.
Thanks for any help 🙂
Replies (9)
Message 2 of 10
I can't readily tell what's missing but I see some questionable things in both screen captures. Post the file here so we can examine it.
Message 3 of 10
agrosantos
ok, here is linked file:
https://go.wetransfer.com/t-QLemZeGwMY
Message 4 of 10
You also need to share your material appearance images.  I would use eTransmit and include Images next time to make it easy.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-share-mater...
But, FWIW, here's my results without those missing render appearance images:
Message 5 of 10
agrosantos
Thanks for help. I think probably my problem with render is with my graphic card. My renders still missing furnitures and lamellas also with high detailing. Your render has complete lamp. In mine are only simple rectangles.
Message 6 of 10
syman2000
Did you update your Revit to 2023.1? When I render, I don't get your missing cabinets as it shown in your rendering.
Message 7 of 10
Bump up the Render Quality/Time. Try these settings and stop the Rendering when you get the results you like.
Message 8 of 10
agrosantos
I have to stop rendering after 15 hours. In attachment are my results. And now also there is no furniture.
When I change rendering option to "until satisfactory" revit pops out text that render size is too much for chosen rendering method. I've changed option for :  "render by level".  I think I have to try render on another PC.
Message 9 of 10
syman2000
Since you have Revit 2023, have you think about installing the free Twinmotion? Perhaps that will help you to have alternative to standard Revit rendering.
Message 10 of 10
Have you considered cloud rendering?
