Cutting the buildign footprint in the toposolid surface
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
mariaome1991
547 Aufrufe, 9 Antworten
I have create a toposolid surface with elevation points in Revit. I have a building that has a basement that has ungrouped elements, it is not grouped. How can I cut the footprint of the building in the toposolid? i wan tto be able to view the building underground in section.
Kind regards
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: mariaome1991
cut it with a mass and hide the mass.
Nachricht 3 von 10
Create a Mass Void that follows your basement overall volume and Cut the Toposolid with it
Constantin Stroescu
Nachricht 4 von 10
I have tried to cut the solid void with the cut tool. Do I have to select the site first and then the void solid?
Also I have tried to adjust the depth of the solid void so that it cuts into the site mass.
Could you offer step by step instructions?
Multumesc frumos pentru ajutor.
Nachricht 5 von 10
Is this what you are trying to do?
Nachricht 6 von 10
Never mind. I'm outta here.  I've got a planet to save.
Nachricht 7 von 10
kelly.colyn
als Antwort auf: barthbradley
...how does this work on an uneven surface praytell?
Nachricht 8 von 10
als Antwort auf: kelly.colyn
not clear what the question is.
Nachricht 9 von 10
kelly.colyn
You give an example of cutting a void in a flat surface above. ...I was asking how to properly make a vertical void cut in a toposolid that is uneven? See screenshots below.
For context, when i place a void cut on the toposolid, with the 3D snapping box checked, i can only make a void within the triangular 3D face of the topossolid.
Without the 3D snapping box checked, I recieve an an error that the void is not cutting anything.
...any help would be appreciated, thanks.
Nachricht 10 von 10
Create the Mass IN-PLACE.  In other words, go to Massing & Site Tab in the Project and pick In-Place Mass.
