Minimum value in a schedule
Hello Fellow Reviteers
I am Building an airflow schedule for a residential building.  For a room the calculation is 0,7*area in dm3/s with a minimum of 7 dm3/s.
Is there a way to give a minimum value to a field so that the red field will be 7 or more?
L.Maas
Use a calculated value. then you can use an IF statement to return the proper result
Louis
Please mention Revit version, especially when uploading Revit files.
It works, thank you!
