Rotating steps
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
russell.beale
312 Aufrufe, 2 Antworten
Rotating steps
I have created steps in Revit between two points ( top and bottom of embankment) but the angle is wrong, is there a way to change this? see below a screenshot of what the steps look like when in combined model. I kind of want to change the steepness of the steps as as such.
thanks
Tags (3)
2 ANTWORTEN 2
Nachricht 2 von 3
georgehobel
als Antwort auf: russell.beale
looks like the stairs are doing what you have asked them to.. they are getting you from elevation 1 to elevation 2.  in order to stretch them out for a more shallow angle... you will need to adjust the length of the run for each tread.
George Hobel
Reflections of Charlotte
Residential Building and Design
Nachricht 3 von 3
There is a parameter for minimum tread depth when you create the stair.  This needs to be increased for the slope to be more shallow.
