Circular chain of references error
manuelmunoz87
manuelmunoz87
So, I'm working on a collaborative file (on my local copy, not the central) and for some reason, when I try to sync, this error appears. Already tried to save, close and reopen, ask other ppl working on the project to sync, save, close and reopen, but the problem does't to away. I can still save locally tho. Any ideas? I would delete the problematic elements, if they weren't already deleted. Ugh
Can you see the element IDs when you get the error?  Is so, you should be able to isolate them and remove the constraints.  If you cannot remove the constraints, you may be able to copy the elements, delete them and paste them back.
Does the full error message read "there is a circular chain of references among the highlighted elements"?  Click on the <Expand> button to drill down to the minutia.
