Change multiple view scale at once
Hi Friends, Do you know how to Change multiple view scale at once? Thanks
XXalessio.amodioXX
Assing view template to current view e.g. scale 1:50 (Be sure scale is checked in view template properties).
Assign the view template to all the view in need.
Great, some of my Title blocks show the scale, but some shows " As Indicated" Do you know why?
RobDraw
Revit does that for you when you have multiple viewports at different scales on a sheet.
Rob
RobDraw
You can do this in a view list (schedule). Make sure to uncheck "Itemize all instances" in Sorting/Grouping.
Rob
XXalessio.amodioXX
If in a single sheet you add Views with different scale, the Title Block family does not know which scale should 'read'.
So if you want to show a specific Scale within the titleblock, change the parameter into a shared parameter text and add the information you want.
Please mark the answer as a solution if it helped you.
Ilic.Andrej
There are some methods that I use to control the scale through the title block family and nesting but all that is "dirty"... Even though this is not a straight answer to your question, I would like to give some advice about the scale displays in general.
We show the scales of all views that we put on one sheet. If the scales are different, they will be displayed using view titles. Then, the scale "as indicated" which is shown on a sheet makes sense. But sometimes, we want the sheet to display the scale of only one of the views. In my experience, this is because wanting to discard the scale of a legend.
It is best practice to avoid making annotation legends using legend views. Legends have scale. Of course, if a legend includes some drawings like those of window shapes etc you would display the scale of that drawing. But if a legend contains just some symbols and text, who cares about the scale of that view? Instead of that, it is better to create a group or a generic annotation family that you can then copy and paste on multiple sheets.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
