Min & Max constraints
21 REPLIES 21
Message 1 of 22
2203 Views, 21 Replies
Is there a way to set constraint dimension to be in between certain values? For example the min. dimension to be 50 and max 500?
21 REPLIES 21
Message 2 of 22
constantin.stroescu
  • create a second parameter and use If formula twice as can be seen in my screenshot:
Constantin Stroescu
Message 3 of 22
alan_eu
Nice, @constantin.stroescu ! I love formulas 🙂
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
Message 4 of 22
in reply to: constantin.stroescu
Thank you very much, I love formulas - I will give this a try!
Message 5 of 22
Message 6 of 22
alan_eu
Do you have the "width" parameter in your family?
Message 7 of 22
alan_eu
If you don't, you will have to create a parameter with this exactly name, including uppercase and by type  (not by instance, in that @constantin.stroescu e.g.)
Message 8 of 22
The formula does not give me an error, however it is not doing its job. What is missing? Why is it not restricting the minimal and maximal dimensions?
Message 9 of 22
alan_eu
Load into your project and try it. Seems to be ok.
Send us the family, please.
Message 10 of 22
in reply to: alan_eu
Am I understanding this correctly? - I have to use the names of parameters in the parent family which are exactly the same as in child family? I think I must have misunderstood....
Also what is the reason I am going BY TYPE and not BY INSTANCE? - Could you please explain?
Message 11 of 22
I have tested it in a project and the formula is not restricting anything. I have used BY TYPE for both the width and its constraint.
Message 12 of 22
alan_eu
I found the erro in this image... You used the parameter width on your model. You would use the calculated value widht constraint.
You can use Type or Instance, you choose.
Message 13 of 22
I am lost now. How do you make calculated value width constraint without having width as a parameter? Can you show me an example please?
Message 14 of 22
alan_eu
You have to use your calculated value as the parameter. The Width is still necessary to change the Width Constraint value
JIFlCAu
Message 15 of 22
constantin.stroescu
as you can see the real Length Parameters here are : W, D and H
Width , in my case, is an Input Parameter for W...
See , how it works when chainging Input Values ...
Formula in Parameter | Search | Autodesk Knowledge Network
Constantin Stroescu
Message 16 of 22
Please advise where I have gone wrong...
I have done as you have suggested:
and when I loaded the family into project, I could not stretch the object by grip arrows:
EDIT: I realized I had it within a group (array). When I have ungrouped it and reloaded to the project (incl. parameters) and tested it, the formula was not working...
Message 17 of 22
constantin.stroescu
I made a short screencast showing how a Family with Type Parameters and one with Instance Parameters work..
Family TypeParameters vs Family Instance Parameters | Search | Autodesk Knowledge Network
Constantin Stroescu
Message 18 of 22
You cannot use a parameter in its own formula. You need an input parameter and an output parameter. Input is to type in value. Output is for the formula and constraining geometry if it is the intent.
Message 19 of 22
Thank you very much for the link to the video! Very much appreciated
Is there any video that you could recommend me that I can study? - what I am trying to figure out is how to make a family that can do this:
The family needs to be stretchable left and right by arrows (the length dimensions will have odd site dimensions). The array of the panels which are in the middle needs to have a constraint (not to go below certain panel width) and also max constraint - once it reaches certain panel width it should make additional panel to fill up the length.
I have made the panels itself stretchable as desired, however I got stuck on everything else:
- array that will fill up certain length
- max & min constraints which will dictate array quantities
- overall width to be stretchable by arrows and not by dimensions listed on the properties panel
- making joint lines invisible
Message 20 of 22
martijn_pater
That one, select the dimension and associate the calculated parameter instead of the width parameter. Follow formula by @constantin.stroescu for the calculated parameter in the first post and it will work.
