Migrate Revit Setting Options
4 REPLIES 4
kshirsagarprasad999
834 Views, 4 Replies
I want to migrate Revit setting options from one machine to another machine.
I have used Revit.ini file for migrating the setting, it does not help me to resolve my issue.
Is there any other way by which i can migrate Revit setting option to other machine?
Tags (2)
4 REPLIES 4
Hi @kshirsagarprasad999
Welcome to the Autodesk community! Smiley Happy
Yes, you can transfer through the revit.ini.
Are you getting some error? What specifically is the issue?
Check this article to Move Elements from One Design Option to Another.
Let me know if this helps!
Entities are missing on one machine, While same file is showing all the entities on other machine.
I want to check if there are any change of Revit option setting.
Forma Design Contest
