Microsoft Surface Book 2 compatibility with Autocad & Revit
Am considering the latest Microsoft Surface Book 2, 15" model with 16GB ram and NVIDIA® GeForce® GTX 1060 discrete GPU w/6GB GDDR5 graphics memory to replace current laptop and will need to be suitable for running both Autocad and Revit. Anyone have experience with the Surface Book 2 running Revit ? Have been in touch with Microsoft and they advise it will be more than capable.
DarrenP
there are many threads on this  from other users on this forum you can read and determine whether or not its worth getting: https://forums.autodesk.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&...
DarrenP
Thanks, however from what have read the majority of the threads relate to Microsoft Surface Book. Am looking to see if there is experience with the Microsoft Surface Book 2 in particular which was launched at the tail end of last year.
DarrenP
 as long as it meets these requirements it should be fine:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles... & http://revit.downloads.autodesk.com/download/2017RVT_RTM/Docs/InProd/Autodesk_Revit_2017_Model_Perfo...
DarrenP
I am also hopeful to find a good answer on this and I am having no luck.  I do see that the graphics card in the 2 is not listed as the recommended graphics card.  The rep at the store says several AEC firms use the 2 with no issue....
The GTX 1060 seems to be used for  HW-accelerationm but on a friends SB2, the performance is mediocre, huge issues with curser lag in particular and multitasking fluidity. Not sure what Audodesk has done for Surface Book 2 users.
dsnorton1
Community Visitor
Community Visitor
Hello, I have the same question that you asked several years ago.  Can you tell me what you decided?  Does the Surface Pro 2,3,4… work well for Revit?
