everything GOES WHITE IN THE 3D VIEW FOR NO FUDGING REASON IN REVIT 2018
3 ANTWORTEN 3
Nachricht 1 von 4
1566 Aufrufe, 3 Antworten
 Hello, people of Autodesk and everyone who tries to work with Revit.  I have more problems and issues with the program but this is the newest and most annoying Ill explain it (I will also explain the others cause I can't work anymore with this s***)
The first problem is the white colours in the 3d view. I'm working in a house and I'm checking stuff or whatever and out of the sudden all the colours disappear and you can barely see anything but if you move the viewport it goes back to normal.
Another issue I  have with Revit is the viewport, sometimes (now less with 2018) it stops working and you have to reset the whole program to be able to move again which is a pain in the A but as I said before this doesn't happen very often.
And the last problem I have which really frustrates me is the wireframe appearing with the consistent colours which make the 3d view very confusing and the program has to be reset so you can see the 3d view normal again
EXTRA
MY extra issue is the pivot, this is very annoying as when you orbit with the viewport or holding shift and middle click it rotates wherever it wants making the 3d model disappeared and you have to zoom out to find it again.
Please I really need help with all of this issue and I have tried to change from consistent colour to wireframe or even see the graphics display options but nada. I would really appreciate the help or I will have to learn ArchiCAD which it will involve a lot of time which I don't really have
Tags (2)
3 ANTWORTEN 3
Nachricht 2 von 4
RobDraw
als Antwort auf: Anonymous
Your graphics issues are probably hardware related.
You can control the pivot point for 3D orbit by selecting an object.
Good luck with ArchiCAD!
Rob
Nachricht 3 von 4
You sure it isn't a loose nut behind the keyboard?
when s*** happens for me, that's usually the culprit.
Nachricht 4 von 4
boubami
Update to WINDOWS 10 and check your graphic card.
