How to put some tabs from the drop down panels in the ribbon area
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
803 Aufrufe, 3 Antworten
Screen Shot 2018-05-29 at 10.35.12.pngHi,
I would like some tabs of the drop down panel shown in the ribbon so they will be easily accessible, like in this build panel, the first 2 big tabs are wall and door. Wall and door were actually in the ribbon before I loaded in content library. Now that I want that ribbon layout, I already reset the ribbon and toolbar according to the official guide and even deselect structure and system tabs I don't use (only using architecture). But they are still in the drop down panel. Any suggestion?
Many thanks
3 ANTWORTEN 3
Nachricht 2 von 4
zemeraloni
als Antwort auf: Anonymous
 Hi @Anonymous
I think the only thing you need to do is press the arrow i marked in the attached pic.
that arrow is expanding and narrowing the ribbon.
Nachricht 3 von 4
boubami
At this stage, the only way is to pin it.
Nachricht 4 von 4
boubami
Impossible. You cannot remove any panels tab. But in the case you'd like to get quick access to a panels tab that is not visible (Surface and Area panel for example), clic on the black arrow at the bottom the panel to expand it.
Once that is done, if you want ot keep the window open during your work, just clic on the pin icon.
That is the only way to get your tabs pemanently in your interface.
