Metric Generic Model two level based
GHASEM_ARIYANI
Advisor Advisor
Message 1 of 9
GHASEM_ARIYANI
hi
What is Purpose or use of familie Template <Metric Generic Model two level based>?
Do ceilings are used to make Or decorative elements of the ceiling and or .... ???
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Replies (8)
Message 2 of 9
Paul_F_Aubin
It has the same behavior as a column. When you load it into a project, it will have a base level and a top level. So you can use it for any element that you wish to constrain between two levels.
Paul F Aubin
Author/Consultant
Check out my books and training videos
paulaubin.com
Message 3 of 9
GHASEM_ARIYANI
hi mr.Paul F. Aubin
Thank you.
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 4 of 9
Yes, but you can't see "top level in schedules, Can't you?
Message 5 of 9
Paul_F_Aubin
I hadn't tested that, but just did now. It appears you are correct. We only just got this feature recently for walls and columns, so hopefully they will add for generic models soon. Bummer.
Paul F Aubin
Author/Consultant
paulaubin.com
Message 6 of 9
I have been told that it is also possible to switch the category family to any of your choosing after you start a new family using this template. This would allow you to edit something such as light fixtures to span between a start and an end level. Normally, you need to host families such as these to one level.
Message 7 of 9
ainQX6BX
Let's say I want to create a stud wall elevation with an array formula with this family, will it be able to attach to a slope roof?
Message 8 of 9
wr.marshall
Message 9 of 9
felix-jaraba
Observer
Observer
hola donde las puedo descargar
