hi
What is Purpose or use of familie Template <Metric Generic Model two level based>?
Do ceilings are used to make Or decorative elements of the ceiling and or .... ???
Solved by Paul_F_Aubin. Go to Solution.
It has the same behavior as a column. When you load it into a project, it will have a base level and a top level. So you can use it for any element that you wish to constrain between two levels.
Paul F Aubin
Author/Consultant
Check out my books and training videos
paulaubin.com
hi mr.Paul F. Aubin
Thank you.
I hadn't tested that, but just did now. It appears you are correct. We only just got this feature recently for walls and columns, so hopefully they will add for generic models soon. Bummer.
Paul F Aubin
Author/Consultant
paulaubin.com
I have been told that it is also possible to switch the category family to any of your choosing after you start a new family using this template. This would allow you to edit something such as light fixtures to span between a start and an end level. Normally, you need to host families such as these to one level.
Let's say I want to create a stud wall elevation with an array formula with this family, will it be able to attach to a slope roof?
posted this as an idea: Schedule the top, bottom and length of a generic model family by two levels - Autodesk Community
